TwinTurbo.NET: Nissan 300ZX forum - OEM waste gate arm length different L/R?
Subject OEM waste gate arm length different L/R?
Posted by wild_maxx on September 12, 2013 at 7:11 PM
  This message has been viewed 245 times.
Message I'm installing new OEM CHRA's into a set of 5-speed turbine housings I picked up a while ago.
The issue I ran into was the length of the waste gate rod and alignment with the WG flap (whatever you call it). The first turbine I bolted up was about 1/2" long of the mounting point while the other turbo was about 1/2" too Short. I swapped the housings and the first turbo (left) now fits great
First attempt
Photobucket Pictures, Images and Photos
Swapped housing
And now everything lines up great.
The second turbo however does not. It's about 1/2" short and required me to pull on the actuator rod a bit to attach it to the flapper. Any ideas as to why this one is so short? Are the turbine housings specific to the left and right side turbos?
Short stuff
