TwinTurbo.NET: Nissan 300ZX forum - 0 Oil Pressure
Subject 0 Oil Pressure
Posted by Khronik on September 09, 2013 at 1:02 AM
  This message has been viewed 178 times.
Message Ive been having oil problems since I got this 90'TT
Im losing oil and smoking at idle randomly. (Valve seals?)
Sometimes the oil pressure will drop to 0 if i let off the throttle into neutral. If im in gear usually the oil pressure is normal, but sometimes it may sit at the first bar(1/4 mark).
I lose oil but have no apparent leaks.
Usually sitting at 1-2quarts after a 3-3.5k mile interval.
Everytime ive ran compression it passes.
Did a leak down last year but not sure if i used enough oil, but compression did not change.
last year when i got it i changed all fluids, did a 120k, and recently replaced fuel rails and all 6 injectors(used from working car from a local z shop, all seem to tick the same).
any suggestions?
1991 NA 2+2 - Pearl White - Auto
1996 NA Coupe - Arctic White - 5Speed
1990 TT Coupe - Aztec Red - 5Speed
