TwinTurbo.NET: Nissan 300ZX forum - Yeah I know, those were done a long time ago and..
Subject Yeah I know, those were done a long time ago and..
Posted by DAYTONAZ on September 07, 2013 at 1:46 PM
  This message has been viewed 244 times.
In Reply To Re: You have 3 problems posted by Tuner_Dev on September 07, 2013 at 10:31 AM
Message even the website I hosted them on didn't retain them. The air regulator is pretty straight forward. When you remove the unit and split it apart just clean everything. It's usually the shutter that gets gummed up and slows its motion. You can hook up a 12v source and watch the spring and shutter move closed. You'll see what I mean when you have it off.
Oem PCV's only. Make sure when u do the compression test the battery is fully charged, engine warmed up, all plugs out, fuel pump relay pulled, throttles wide open.
