TwinTurbo.NET: Nissan 300ZX forum - You have 3 problems
Subject You have 3 problems
Posted by DAYTONAZ on September 07, 2013 at 9:59 AM
  This message has been viewed 261 times.
In Reply To High Idle @1500, Temp rising to almost H, Exhaust Smoke!??!! posted by Tuner_Dev on September 06, 2013 at 02:58 PM
Message The high idle is addressed with the Air Regulator,
[ http://twinturbo.net/nissan/300zx/forums/technical/view/920429/Idle-valve-IAA-and-air-regulator-how-to-part-1.html ]
The temp problem is the T-stat and possibly a coolant leak. So the remedy to that is R&R the t-stat and pressure check the cooling system.
The smoke issue with good compression could be turbo seals leaking, bad PCV valves if you used non-oem. The easy check for the oil is to pull the hoses before the throttle valves and check for residue. Also pull the balance tube and look in the plenum with a flashlight for oil puddling around the rear corners and near the pcv ports.
