TwinTurbo.NET: Nissan 300ZX forum - Rising then Falling Temps inducate T-Stat Problem
Subject Rising then Falling Temps inducate T-Stat Problem
Posted by Cjw3 on September 06, 2013 at 3:46 PM
  This message has been viewed 361 times.
In Reply To High Idle @1500, Temp rising to almost H, Exhaust Smoke!??!! posted by Tuner_Dev on September 06, 2013 at 02:58 PM
Message If you have a Slow to act T-Stat, the temp will rise and then fall. OR you could have a Leaking Head Gasket, that is allowing bubbles to get trapped behind the T-Stat, causing the same symptoms..
My Suggestion.
1) Check for Rad fluid and containments.. clean as necessary
2)Change the T-Stat
3) ONLY IF THE PROBLEM OF OVERHEAT BEFORE SETTLING PERSISTS, remove the T-Stat, and check for combustion gasses in the Rad Fluid.. for possible head gasket leak..
I'm no good on the Smoke Issue.. I'm NA
Cj
