TwinTurbo.NET: Nissan 300ZX forum - You should start with the obvious issues you've
Subject You should start with the obvious issues you've
Posted by soulpwr on September 06, 2013 at 12:17 AM
  This message has been viewed 154 times.
In Reply To Even though I've done all those tests, I don't see how posted by inf on September 05, 2013 at 09:18 PM
Message already located first. Fix the PCV issue and change the valves with OEM replacements if necessary. Inspect the pistons and plugs for wetness. A compression test will tell you if you have a ring issue if you retest it with a little oil and the numbers go up.
It sounds to me like you probably have a blow by issue or a car that has been poorly maintained over the years and needs a bunch of work.
