TwinTurbo.NET: Nissan 300ZX forum - Re: Set the TPS Voltage to .45 Volts
Subject Re: Set the TPS Voltage to .45 Volts
Posted by 1990Z32Guy on September 05, 2013 at 9:25 PM
  This message has been viewed 197 times.
In Reply To Set the TPS Voltage to .45 Volts posted by Cjw3 on September 05, 2013 at 08:36 PM
Message I had set the TPS properly before, however I will check the sensor settings as I believe I may have set it using resistance on the multimeter. I will attempt to adjust it using voltage this time.
The new CTS tested at about 1k ohms @ ~100*F
Thank you for the help guys, this problem has me scratching my head because everything else on the car is working perfectly.
