TwinTurbo.NET: Nissan 300ZX forum - Backfire out the Intake?.. New Engine?
Cjw3
on September 05, 2013 at 10:23 AM
Re: Are you insinuating it's misfiring due to it being rich?
posted by scttz90
on September 05, 2013 at 05:24 AM
Sounds like a LEAN problem.. or Valve Timing/Adjustment.. I think you need to go over the basics.. Are the Injectors proper for the Tune?.. what kind of Compression Pressures are you getting?.. Check Cam Timing..
Something is Fubar
Cj
popping out exhaust
scttz90
20:51:03 09/04/13
inf
22:43:02 09/04/13
scttz90
05:24:33 09/05/13
Backfire out the Intake?.. New Engine? -
Cjw3
10:23:33 09/05/13
Corection.. Exhaust.. Still check everything (n/m)
Cjw3
10:58:43 09/05/13
Just figured it out
scttz90
19:44:26 09/05/13
could it just be bad connections to injectors?
Medallion Man
06:22:17 09/05/13
Re: could it just be bad connections to injectors?
scttz90
09:48:24 09/05/13
Make sure you're using the right NGK plugs and
300ZMang
11:17:43 09/05/13
