TwinTurbo.NET: Nissan 300ZX forum - could it just be bad connections to injectors?
Medallion Man
on September 05, 2013 at 6:22 AM
popping out exhaust
posted by scttz90
on September 04, 2013 at 08:51 PM
also worth doing to full connector check clean up..
particularly for PTU and CAS, also check the EGI relay (main fuse box) for corrosion on connectors.
popping out exhaust
scttz90
20:51:03 09/04/13
Are you insinuating it's misfiring due to it being rich?
inf
22:43:02 09/04/13
Re: Are you insinuating it's misfiring due to it being rich?
scttz90
05:24:33 09/05/13
Backfire out the Intake?.. New Engine?
Cjw3
10:23:33 09/05/13
Corection.. Exhaust.. Still check everything (n/m)
Cjw3
10:58:43 09/05/13
Just figured it out
scttz90
19:44:26 09/05/13
could it just be bad connections to injectors? -
Medallion Man
06:22:17 09/05/13
Re: could it just be bad connections to injectors?
scttz90
09:48:24 09/05/13
Make sure you're using the right NGK plugs and
300ZMang
11:17:43 09/05/13
