Re: hmm.. posted by Tuner_Dev on September 04, 2013 at 01:54 AM
disconnected it was at 900rpm? It should be like 500-600rpm with it all the way in. Have you tested compression? An easier way is a combustion leak tester you use with the radiator to check for gases in the cooling system. Takes 2 minutes...
