hmm.. posted by inf on September 04, 2013 at 12:47 AM
smoke is kinda whitish and smells like exhaust fumes. the same smell you get when you have a big exhaust leak. i did disconnect the yellow connector before adjusting the screw all the way in. At first, it did lower the idle from 2k to around 900 but then i drove it around the block and hit the first stop sign and idle was at 1500 and smoke coming out the back. I'll change pcv tomorrow and report back. I havent touched the TPS and haven't checked timing. Car has only code 42 after being driven.
