TwinTurbo.NET: Nissan 300ZX forum - correct the restrictors inside the hoses
Subject correct the restrictors inside the hoses
Posted by Khronik on September 03, 2013 at 11:24 PM
  This message has been viewed 172 times.
In Reply To What if he took them out posted by OverZealous (CT) on September 03, 2013 at 09:04 PM
Message i had replaced 4 of the 5 in jan/feb when i did the timing belt
thought i had them correct(tried matching the original hoses) but now im not sure
i had replaced the valve covers recently and swapped them around to where the restrictors were all facing the same directions
- best way i can describe that is the whisker part of the restrictors all going the same direction. all going right i believe.
changed them because when i did the valve covers a couple months back it seemed like i had them incorrect to begin with.
yes they are formed but there isnt a definite way to confirm due to the hoses for the most part are the same.
front two are what seemed to be identical as well as the back to that connect to the pcv valves. the only one i can verify for sure is correct is the one by the egr.
1991 NA 2+2 - Pearl White - Auto
1996 NA Coupe - Arctic White - 5Speed
1990 TT Coupe - Aztec Red - 5Speed
