TwinTurbo.NET: Nissan 300ZX forum - For the second time .... does the compressor produce cold
Subject For the second time .... does the compressor produce cold
Posted by zellamay on September 03, 2013 at 12:36 PM
  This message has been viewed 259 times.
In Reply To Re: So I assume you've run 12v to the compressor with the posted by MachinistZ on September 02, 2013 at 10:01 PM
Message air when you do that? The only way it could is if you do that with the engine running, which you still have not said. ... (I don't blame you for not wanting to add a switch. I don't know you, and whether you needed a quick cheap fix. I would only do that to a lower-valued car.)
