TwinTurbo.NET: Nissan 300ZX forum - So I assume you've run 12v to the compressor with the
Subject So I assume you've run 12v to the compressor with the
Posted by zellamay on September 02, 2013 at 7:48 PM
  This message has been viewed 319 times.
In Reply To Re: is that the only thing that doesn't work? posted by MachinistZ on September 02, 2013 at 11:19 AM
Message engine running, and cold air comes into the cabin. This may be like a problem I had with my first Z32, a 95 NA. I was told I needed to replace the whole a/c control mod = $900. Instead, I wired straight to the compressor, through a switch that I mounted on the shifter, so it was always easy to reach. I manually controlled the on-off of the compressor for the rest of the time I owned the car. Seems hokey I know, but it worked and cost $5. An inadvertent bonus was that I could quickly turn the compressor off when I needed more power (remember, it was an NA).
