| Subject |
yeah, i agree with BlackTwins... first thing to do |
| Posted by |
Medallion Man on September 01, 2013 at 5:18 AM |
This message has been viewed 162 times. |
| In Reply To |
Re: Re: 90TT Won't Start, goes bom-bom-bom loudly,shakes,dies posted by BlackTwins on September 01, 2013 at 03:06 AM |
| Message |
is check all the electrical connections for corrosion and good contact.. (CAS, PTU, TPS, MAF, Coils, injectors, battery ..etc.. the other issue is that hte battery might not be good enough to start the car after so long.so it could be you're flooding it as well and then it will never start until it dries up. either put a new battery in it or use a good jump one. if you have problems with flooding, unplug the fuel pump fuse and crank it will throttle full open for a few minutes. then put fuse back in and try as normal. MachinistZ could also be right but lets hope its not that. try the easy things first but as he says there is no harm in checking the fuel pressure.
| Follow Ups |
Post a Followup |
