TwinTurbo.NET: Nissan 300ZX forum - Wastegates aren't an on/off, so they're probably
Subject Wastegates aren't an on/off, so they're probably
Posted by Poppe on August 28, 2013 at 10:07 AM
  This message has been viewed 233 times.
In Reply To Re: I bet you got a ripped coupler somewhere posted by TwinTurboByrd on August 28, 2013 at 09:03 AM
Message starting to crack open and not allowing you to build boost properly. I'd recommend a boost controller because that will nearly work as an on/off (meaning the WGs won't see boost until whatever you set it at). This is what the GAIN setting does on a boost controller.
