TwinTurbo.NET: Nissan 300ZX forum - the egr was soley made for nOX...
inf
on August 27, 2013 at 1:09 PM
Didn't pass smog in CA
posted by ZKutch
on August 26, 2013 at 11:59 PM
at any rate, are you cats bolt on or welded? Make sure there's no leaks before the cats.
ZKutch
23:59:25 08/26/13
High NO indicates lean mixture. If you look at
JMartz
09:24:24 08/27/13
Re: High NO indicates lean mixture. If you look at
ZKutch
10:40:40 08/27/13
Your test indicates no problem with the cats. You
JMartz
12:02:30 08/27/13
Try searching this site for info on passing emissions.
zellamay
11:03:58 08/27/13
Re: Didn't pass smog in CA
Cjw3
11:25:07 08/27/13
Re: Re: Didn't pass smog in CA
ZKutch
19:33:41 08/28/13
the egr was soley made for nOX... -
inf
13:09:23 08/27/13
Re: the egr was soley made for nOX...
ZKutch
19:35:19 08/28/13
Have to retard the CAS timing with no egr. (n/m)
Woody75 (Denver)
13:22:59 08/27/13
dumbazz
20:36:56 08/27/13
