TwinTurbo.NET: Nissan 300ZX forum - Re: Didn't pass smog in CA
Subject Re: Didn't pass smog in CA
Posted by Cjw3 on August 27, 2013 at 11:25 AM
  This message has been viewed 324 times.
In Reply To Didn't pass smog in CA posted by ZKutch on August 26, 2013 at 11:59 PM
Message Looking at your sheet, you got a NA on the Ignition Timing.. They do not check it??
Thinking I'm remembering something about retard the timing to 5 Deg BTDC. that will reduce the burn rate.. drop the burn temps temps and lower the NOx.. should bring up the HC's but you have new cats, and they are doing a good job now..
Also on the sheet, is 'Modified'.. for other emission .. will that pass with a Modified on there?.. Does the Smog Tech know about the EGR?..
Cj
