TwinTurbo.NET: Nissan 300ZX forum - 4th main bearing clearance?
Subject 4th main bearing clearance?
Posted by wild_maxx on August 25, 2013 at 5:46 PM
  This message has been viewed 702 times.
Message I am in the process of assembling my short block but I've run into a bit of a snag.
main bearings 1-3 are all coming out with about .0015 clearance using green plastigauge. The 4th main is showing .001 clearance which is a bit tight according to the specs.
I ordered my bearings based off of the grade stampings on the block/crank.
mains 1-3 came out fine:
#4 is the tight one
So I'm guessing the solution is to order a larger grade #4 bearing but I find it odd that its on the tight side using the stampings on the block/crank.
