| Message |
The ECU must have the PROM unsoldered that is in it, and a Sockett replaced.. and with an E-Bay PROM.. what is your warranty?.. NONE.. No, the prom must be proper for the injectors.. they do not learn..Spend the $200 or so on an ECU exchange from Z1 or the like and it will be Socketted, and have your Goodies programmed into it.. AND for $50 more, you can have the prom changed every time you change the car.. Build a reputation with a supplier and keep it.. DO NOT SHOP CHEEPEST.. you will get burned.. Cj
