TwinTurbo.NET: Nissan 300ZX forum - Re: Re: Re: Re: ?????????????
Subject Re: Re: Re: Re: ?????????????
Posted by Cjw3 on August 25, 2013 at 2:09 PM
  This message has been viewed 206 times.
In Reply To Re: Re: Re: ????????????? posted by Exia on August 25, 2013 at 02:03 PM
Message IF the ECU is triggered to be in Idle Mode ( TPS set properly, and procedure done properly ) then the Timing should be Rock Solid at what ever you put it at.. if the timing wanders, it's not in Idle Mode, and the Ignition will be wrong.. Sounds like you might have it in idle mode..
14 Deg is OK.. I'll look up the numbers and see what I can find.. Does your Chasis have AIV's hooked up?.. I'm not sure of the AIV Cut off date for TT's, as I'm a NA guy..
Cj
