| Subject |
Check for fuel leaks, using the paper towel, or talcum |
| Posted by |
zellamay on August 25, 2013 at 1:45 PM |
This message has been viewed 263 times. |
| In Reply To |
Long cranking time, with raw fuel smell posted by ZkillS on August 25, 2013 at 08:52 AM |
| Message |
powder tests. It seems like a fuel pressure leak, which can be dangerous. Gas burns cars. It runs okay going down the road because your pump has had time to overcome the leak, but it's still leaking. .... Are you sure you cycled the fuel pump properly, several times, before determining that it had no effect? If it is leaking, and you wait at all between cycles, or before trying to start the car, you'll lose what pressure you have quickly.
| Follow Ups |
Post a Followup |
