| Message |
I went over to a machine that I could View the Video you Posted.. The ONLY thing I can determine from the Video, is the Car Starts, Runs, and Squeeks from loose Belts.. might be a Bad Idlers in there also .. Looks like it Idles properly, and I can not hear any other problems with the Car. From what I can here, the exhaust note sound proper.. The problem I have from this point, is I have to rely on your description of a problem, that you do not understand. I'm thinking you need to take it to someone that knows Z's to have them help you diagnose.. I like to use the Voltage Output from the Narrow Band O2's from each Bank, to help me figure out what the ECU is 'Thinking'.. and there for what is problem is.. but the car has to be right in front of me to do that. I've eluded to the O2 sensor Monitoring in my second few things more post.. The ECU number will just verify you have the PROPER ecu for that Car.. Is it an Auto chasis, and an Auto ECU.. then there is the AIV's issue.. as long as you do not have AIV's on the car hooked up, and the ECU is not wanting AIV's you should be good there.. But I'm not hearing a problem with fueling on the Vid.. I only hear Belts and Pulleys problem Cj
