TwinTurbo.NET: Nissan 300ZX forum - Re: Re: Re: A few things more
Subject Re: Re: Re: A few things more
Posted by Cjw3 on August 23, 2013 at 10:57 PM
  This message has been viewed 234 times.
In Reply To Re: Re: A few things more posted by Exia on August 23, 2013 at 08:57 PM
Message You have a '93 chassis.. what year is the ECU.. is the ECU looking for AIV's at idle that you might not have.. if so your idle will be rich..
Have you set the .45 TPS Voltage?
Does the Idle Ignition stay at 15 Deg?
Does the O2 Sensor Voltage drop off to less than .1 Volt at Idle ( Lean) or does it stay >.6 ( rich ).. or is it still in Stoch Hunt, where it dithers between Rich and lean..
If the IAV's are not an issue then..
If it's not at 15 Deg, <.5 volts TPS and O2 Sensor Voltage <.1 volt then it's not in warm idle mode, and that could be your Idle Speed problem.. is it still in cold start mode?.. ( Temp Sensor I Mentioned )
Cj
