TwinTurbo.NET: Nissan 300ZX forum - Should I be connecting the little connector part of the
inf
on August 23, 2013 at 8:47 PM
Trying to bench compression test an engine
posted by inf
on August 23, 2013 at 08:40 PM
solenoid to positive (the connector goes to the ignition switch, correct?) or should I use the smaller stud and connect that with the bigger stud...but that doesn't make sense since that's now how it works on the car...
inf
20:40:40 08/23/13
Should I be connecting the little connector part of the -
inf
20:47:46 08/23/13
I can also spin it by hand no problem. (n/m)
inf
21:12:51 08/23/13
perhaps the starter is on the transmission too tight..hmm... (n/m)
inf
21:40:43 08/23/13
i think i remember how i did it before
inf
23:12:07 08/23/13
Hmm...would having an engine from an auto and using
inf
14:46:49 08/24/13
it looks like the starter gear gets stuck after it tries to
inf
14:53:40 08/24/13
Did you put a manual flywheel on?
ZXoltan
18:07:22 08/24/13
ya, the manual flywheel is on... (n/m)
inf
20:45:59 08/24/13
Also, flywheel must be for NA if u are using NA tranny
ZXoltan
07:42:49 08/26/13
the starter can't even get past compressing one cylinder
inf
20:49:17 08/24/13
You are not getting enough juice (electrical power).
zellamay
20:58:02 08/24/13
ya i just and I mean just read someone elses reply
inf
20:59:55 08/24/13
When jumping cars, I've had the experience of cheap
zellamay
23:52:52 08/24/13
i used thicker cables, like twice as big and got it goin...
inf
22:35:37 08/26/13
