TwinTurbo.NET: Nissan 300ZX forum - I would go with a better LSD rather than a ratio change.
Broke_as_****
on August 23, 2013 at 2:36 PM
Yes and possibly less wheel spin due to ratio change. (n/m)
posted by ChaseGrayTT
on August 22, 2013 at 08:43 PM
A twenty year old, six digit mileage viscous differential isn't going to provide much lock up regardless of what gearing it's hooked up to.
TT rear subframe on an NA?
ChaseGrayTT
15:28:46 08/21/13
I would stick with the NA
-Grimm-
17:02:47 08/21/13
You think so?
ChaseGrayTT
17:23:52 08/21/13
You MAY see better traction
-Grimm-
09:24:47 08/22/13
You haven't said why you are considering the swap.
zellamay
21:34:18 08/21/13
I'm running BF Goodrich KDWs
ChaseGrayTT
23:33:37 08/21/13
So the goal is a stronger diff? (n/m)
zellamay
13:43:29 08/22/13
ChaseGrayTT
20:43:42 08/22/13
I would go with a better LSD rather than a ratio change. -
Broke_as_****
14:36:49 08/23/13
This subframe has low miles.
ChaseGrayTT
08:11:40 08/25/13
I have a TT subframe on my swapped NA.
SuparexTT
15:04:41 08/25/13
Keep the NA.. good enough. (n/m)
CmyZ
21:15:59 08/25/13
