TwinTurbo.NET: Nissan 300ZX forum - Check the Big Line out front, see if it's cold..
Cjw3
on August 22, 2013 at 5:09 PM
93 zx ac blows but not cold help.
posted by blackrob44
on August 22, 2013 at 07:51 AM
I just had a problem with the '95 NA where the Heater Core Water Valve, Stuck open.. could not get the heat to turn off.. Ended up replacing the heater Core, and now the Heater will shut off, and the AC Works FINE..
Cj
blackrob44
07:51:38 08/22/13
are the fuse and relay in the engine bay OK?
Medallion Man
08:56:41 08/22/13
is your compressor turning?
aliaZ
10:42:40 08/22/13
Re: is your compressor turning?
blackrob44
11:06:19 08/22/13
blackrob44
11:07:19 08/22/13
how much did you put in?
aliaZ
12:25:46 08/22/13
Check the Big Line out front, see if it's cold.. -
Cjw3
17:09:43 08/22/13
93's take R12, did you use the correct refrigerant? (n/m)
Fast300
22:16:03 08/22/13
