TwinTurbo.NET: Nissan 300ZX forum - Re: Pull the plugs and put a 27mm socket on the crank
Subject Re: Pull the plugs and put a 27mm socket on the crank
Posted by SouthGaZ on August 21, 2013 at 12:15 PM
  This message has been viewed 198 times.
In Reply To Pull the plugs and put a 27mm socket on the crank posted by Krazyd27(Houston) on August 21, 2013 at 11:40 AM
Message Getting the starter tested first today when i get off then i will try that. Is thats clockwise or counter? If it rotates it should be fine right?
