TwinTurbo.NET: Nissan 300ZX forum - Pull the plugs and put a 27mm socket on the crank
Krazyd27(Houston)
on August 21, 2013 at 11:40 AM
Engine locked up?
posted by SouthGaZ
on August 21, 2013 at 11:05 AM
And rotate it by hand to check if its seized. Check inside the cylinders for fuel. If these are good then have your starter tested to make sure it's working properly.
Engine locked up?
SouthGaZ
11:05:34 08/21/13
Pull the plugs and put a 27mm socket on the crank -
Krazyd27(Houston)
11:40:34 08/21/13
Re: Pull the plugs and put a 27mm socket on the crank
SouthGaZ
12:15:33 08/21/13
If it rotates its not seized (n/m)
-Grimm-
17:01:21 08/21/13
Rotate clockwise, looking at front of engine (n/m)
ZXoltan
04:04:37 08/22/13
