TwinTurbo.NET: Nissan 300ZX forum - how would i go about correcting the firing order? Ive alread
Hydrus (Dallas)
on August 20, 2013 at 10:50 PM
there is one rare exception
posted by Zvil (FL)
on August 20, 2013 at 03:09 PM
y swapped ptus and no change. I know it has to be a spark issue or ptu. Could it even be an ecu issue? Was driving fine. Didnt drive it for a day then the second day started it up and had a dead cylincer.
How can you tell if you have a "weak" spark?
Hydrus (Dallas)
13:31:19 08/20/13
Have you checked the spark plugs out?
-Grimm-
14:27:32 08/20/13
Yeah that was the first thing i did and had a visible spark
Hydrus (Dallas)
18:45:00 08/20/13
everytime I got no spark was a bad PTU or connection
Zvil (FL)
15:06:53 08/20/13
Zvil (FL)
15:09:50 08/20/13
Hydrus (Dallas)
18:47:38 08/20/13
If I were you, I would first make sure there is continuity
Zvil (FL)
19:28:25 08/20/13
If your PTU subharness is crimp connected on
-Grimm-
09:57:22 08/21/13
when I say "crimp" I mean bend the tabs in the connector (n/m)
Zvil (FL)
11:01:10 08/21/13
Thanks ill be back with results! (n/m)
Hydrus (Dallas)
14:01:17 08/21/13
Is your PTU subharness still in place?
-Grimm-
09:42:26 08/23/13
how would i go about correcting the firing order? Ive alread -
Hydrus (Dallas)
22:50:40 08/20/13
You haven't necessarily eliminated a fueling issue.
Evan_Wright (Ca)
19:06:46 08/20/13
I pulled the cas and spun it by hand and the injector
Hydrus (Dallas)
13:59:59 08/21/13
Probably not. You seem to be doing a good job narrowing
Evan_Wright (Ca)
14:24:14 08/21/13
I really appreciate man. Ill post any new updates (n/m)
Hydrus (Dallas)
16:14:35 08/21/13
Results: No change at all. cleaned and crimped down all
Hydrus (Dallas)
14:18:52 08/22/13
Have any friends in Dallas with a spare ECU to try? (n/m)
-Grimm-
09:39:41 08/23/13
