TwinTurbo.NET: Nissan 300ZX forum - O2 Corection is a Secret!
Subject O2 Corection is a Secret!
Posted by Cjw3 on August 20, 2013 at 4:37 PM
  This message has been viewed 219 times.
In Reply To or is it cause the o2's will sense rich and lean it out posted by inf on August 20, 2013 at 01:51 PM
Message The ECU forum for 300ZX ECU tuning talks BRIEFLY about how the O2 Correction Works.. but only mentions that all the information the poster had was confidential.. and he could not post about it.. ( Thanks.. )
The ECU's I'm familiar with can only do a 30% Correction.. your machine was programmed for 370's and has some 500's in it.. LIKELY the ECU will not be able to pull enough fuel to lean out the 500's.. but it will pull fuel on the 370.. so it will run lean at cruse..
Idle is a different animal.. the 300 ECU does not use O2 Sensor correction for Idle.. so the 500's will be running rich, and the 370 will be running proper.. LIKELY that is why the idle is so good.. you do not have a lean cylinder.. just rich ones..
Still hunting for a way to get O2 Sensor correction at Idle..
Cj
