TwinTurbo.NET: Nissan 300ZX forum - Maybe verify that the solenoid valve which controls the
Subject Maybe verify that the solenoid valve which controls the
Posted by jzack on August 15, 2013 at 8:10 PM
  This message has been viewed 154 times.
In Reply To EGR trouble code posted by jlk69 on August 15, 2013 at 07:14 PM
Message EGR vacuum is good? I'm assuming the '96 system works similar as earlier years -- that is, has an electrically controlled vacuum valve? Could be as simple as a bad electrical connection too?
If valve solenoid is bad - could try putting a resistor across the harness connector. ECU would then think the solenoid is good?
