TwinTurbo.NET: Nissan 300ZX forum - strike the aluminum around the pin with a hammer and it will
Dane (Houston)
on August 14, 2013 at 11:45 PM
Front Driver Side King Pin Assembly
posted by ZXRider
on August 14, 2013 at 11:27 AM
fall out. oldest trick in the book, screw pullers and forks
ZXRider
11:27:19 08/14/13
don't use a pickle fork to remove the ball joints
Zvil (FL)
20:08:37 08/14/13
I wonder if I can rent that from the local parts store
ZXRider
01:53:26 08/15/13
Pretty sure you can "borrow" them from Advance or Autozone
ZXoltan
14:51:51 08/15/13
strike the aluminum around the pin with a hammer and it will -
Dane (Houston)
23:45:43 08/14/13
Screw puller and forks?
ZXRider
01:52:00 08/15/13
I believe he meant "screw" in the insult sense (n/m)
Zvil (FL)
13:58:39 08/15/13
I know that trick.... and you may have the magic touch
Zvil (FL)
13:56:59 08/15/13
You can change the king pin but its not going to fix it.
Joe@ZSpeedperformance
01:52:43 08/18/13
