Emission Control System Visual Inspection/Functional Check Result %C02 %O2 HC (PPM) CO (%) Test RPM MEAS MEAS MAX GP MEAS MAX GP MEAS IDLE 850 13.7 1.5 120 290 338 1.00 2.50 1.44 2500 2320 10.6 0.8 140 270 288 1.00 2.50 6.90failed GP at 2500rpm with (270) failed HC (PPM) MEAS idle with (338) failed HC (PPM) MEAS 2500rpm with (288) failed CO(%) MEAS 1.44 idle failed CO(%) MEAS 6.90 2500RPM Since then I clean my dual pop chargers with simple green replaced the spark plugs with NGK Iridium IX heat range 8 complete oil/filter change. Is there anything else I should do to hopefully pass the smog check here in California.
