TwinTurbo.NET: Nissan 300ZX forum - don't use a pickle fork to remove the ball joints
Subject don't use a pickle fork to remove the ball joints
Posted by Zvil (FL) on August 14, 2013 at 8:08 PM
  This message has been viewed 329 times.
In Reply To Front Driver Side King Pin Assembly posted by ZXRider on August 14, 2013 at 11:27 AM
Message instead, use a pitman arm puller. Pickle forks are easy to use but they can damage the grease boot. Lift both wheels off the ground to avoid the sway bar binding the suspension. Have new cotter pins available, used ones like to snap.....especially if the car is from a salty area. Be gentle with the ABS sensor.
*disclaimer*: all that I say may be true or I may be completely wrong and I accept that.... please, it is your duty as another person on the internet to impolitely tell me how wrong I am :)
"The dreaded 2nd windshiled wiper swipe when you turn it off its almost like tis showing you that it's boss, and it doesn't have to stop when you tell it to :("-College Boy
(discussion on ptu relocation)
"No good reason to put it there anyway. -Bernie (NoVA)
False -vorpalZ
False. -Bernie (NoVA)
You're correct, there are 3 good reasons -vorpalZ
Wow, right again, just remembered another, make that 4 -vorpalZ"
XD
