TwinTurbo.NET: Nissan 300ZX forum - Re: Damn...
Subject Re: Damn...
Posted by rhombicblue on August 14, 2013 at 1:48 PM
  This message has been viewed 248 times.
In Reply To Damn... posted by -Grimm- on August 13, 2013 at 11:56 PM
Message If you truly have the actual compression numbers listed in your post, the air/fuel mixture in each cylinder will not fire. Pistons compress the air/fuel mixture during the compression stroke. During the compression stroke, When the piston of an engine compresses the charge, an increase in compressive force supplied by work being done by the piston causes heat to be generated. The compression and heating of the air-fuel vapor in the charge results in an increase in charge temperature and an increase in fuel vaporization. The increase in charge temperature occurs uniformly throughout the combustion chamber to produce faster combustion (fuel oxidation) after ignition.
The increase in fuel vaporization occurs as small droplets of fuel become vaporized more completely from the heat generated. The increased droplet surface area exposed to the ignition flame allows more complete burning of the charge in the combustion chamber. Only gasoline vapor ignites. An increase in droplet surface area allows gasoline to release more vapor rather than remaining a liquid.
The more the charge vapor molecules are compressed, the more energy obtained from the combustion process. The energy needed to compress the charge is substantially less than the gain in force produced during the combustion process. For example, in a typical small engine, energy required to compress the charge is only one-fourth the amount of energy produced during combustion.
No, I didn't not think or write the above explanation, but it was the best one I could find on the Internet.
