TwinTurbo.NET: Nissan 300ZX forum - Anyone ever had an issue of a PCV hose cracked causing
Subject Anyone ever had an issue of a PCV hose cracked causing
Posted by inf on August 12, 2013 at 7:03 PM
  This message has been viewed 293 times.
Message high idle? 1100rpm? The brake cleaner method doesn't detect a vacuum leak as far as I can tell, but the boost leak method definitely produces a leak. I've tried all other ideas for this high idle including the TPS, other vacuum leaks, throttle body position, coolant sensor, iacv electrical tests...
