TwinTurbo.NET: Nissan 300ZX forum - TPS Switch
Subject TPS Switch
Posted by Cjw3 on August 10, 2013 at 11:09 AM
  This message has been viewed 145 times.
In Reply To TPS question. What does the connector on the front of the posted by Attridge_300ZX on August 10, 2013 at 10:42 AM
Message The Plug on the front of the TPS, is the TPS Switch.. closes at Idle.. The Dangly Plug is the actual TPS 'Sensor' where the 0-5 Volt sig comes from..
The Switch is a back up for the 'Sensor' if it should go bad.. and the documents have the switch not being used unless the TPS Sensor quits working
Cj
