TwinTurbo.NET: Nissan 300ZX forum - Even more information
-Grimm-
on August 10, 2013 at 1:39 AM
1990 TTZ Won't Fire
posted by -Grimm-
on August 09, 2013 at 08:08 AM
The car overheated bad, which is how the owner realize the head gasket was gone. The timing cover that the PTU mounts too looks like it may have warped, which makes me think the PTU may have overheated?
1990 TTZ Won't Fire
-Grimm-
08:08:45 08/09/13
A little more info...
-Grimm-
08:13:04 08/09/13
If you have spark, fuel and air, it should start. I would
CmyZ
09:12:35 08/09/13
I will see if I can borrow an ECU.
-Grimm-
10:38:35 08/09/13
What possible causes would make the ECU to go bad?
-Grimm-
10:49:44 08/09/13
Re: 1990 TTZ Won't Fire
rhombicblue
17:59:15 08/09/13
I just replace the head gaskets
-Grimm-
18:58:02 08/09/13
its turning over or u just hear the starter spinning? (n/m)
300ZMang
19:14:22 08/11/13
It's cranking, I can see the fan spinning
-Grimm-
20:35:03 08/11/13
I tested the PTU with a multimeter per the FSM
-Grimm-
16:03:24 08/12/13
Even more information -
-Grimm-
01:39:11 08/10/13
Re: Even more information
rhombicblue
19:25:44 08/10/13
Damn...
-Grimm-
23:56:18 08/13/13
try another compression tester to double check
dvice
02:59:29 08/14/13
could also try leakdown (n/m)
dvice
03:07:33 08/14/13
I was considering running a leak down test...
-Grimm-
12:27:00 08/14/13
Re: Damn...
rhombicblue
13:48:25 08/14/13
