TwinTurbo.NET: Nissan 300ZX forum - I just replace the head gaskets
Subject I just replace the head gaskets
Posted by -Grimm- on August 09, 2013 at 6:58 PM
  This message has been viewed 229 times.
In Reply To Re: 1990 TTZ Won't Fire posted by rhombicblue on August 09, 2013 at 05:59 PM
Message I did all the work myself, done it a few times on my other Z's. I'm sure the timing belt is set properly and tensioned properly. The valve timing will be off by 0.5 degrees from decking but that's it, not enough to cause interference.
Ok let me rephrase the "freewheeling", it sounds like a car cranking over with the coil disconnected. Some resistance and I can hear valve events in the exhaust, but definitely no fire.
Also, ECU gives me code 55.
I will check some voltages around the engine bay and put some temporary grounds in to eliminate that.
I am also trying to find an ECU and PTU in NorCal to borrow.
