In the tech section for the apexi boost controller install at number 18 it says to remove the boost hose underneath the intake throttle hoses. From what I gather it wants to have this hose T'd to the waste gate, the original connection underneath the intake hose and finally the COM port. If I remember correctly from installing my other boost controllers (obviously my memory is lacking since I have to refer to the tech) the connection under the intake hoses are vacuum capped off, not T'd since the NO port is the connection that monitors pressure, correct?
