TwinTurbo.NET: Nissan 300ZX forum - If you have spark, fuel and air, it should start. I would
CmyZ
on August 09, 2013 at 9:12 AM
1990 TTZ Won't Fire
posted by -Grimm-
on August 09, 2013 at 08:08 AM
test with another ECU..
1990 TTZ Won't Fire
-Grimm-
08:08:45 08/09/13
A little more info...
-Grimm-
08:13:04 08/09/13
If you have spark, fuel and air, it should start. I would -
CmyZ
09:12:35 08/09/13
I will see if I can borrow an ECU.
-Grimm-
10:38:35 08/09/13
What possible causes would make the ECU to go bad?
-Grimm-
10:49:44 08/09/13
Re: 1990 TTZ Won't Fire
rhombicblue
17:59:15 08/09/13
I just replace the head gaskets
-Grimm-
18:58:02 08/09/13
its turning over or u just hear the starter spinning? (n/m)
300ZMang
19:14:22 08/11/13
It's cranking, I can see the fan spinning
-Grimm-
20:35:03 08/11/13
I tested the PTU with a multimeter per the FSM
-Grimm-
16:03:24 08/12/13
Even more information
-Grimm-
01:39:11 08/10/13
Re: Even more information
rhombicblue
19:25:44 08/10/13
Damn...
-Grimm-
23:56:18 08/13/13
try another compression tester to double check
dvice
02:59:29 08/14/13
could also try leakdown (n/m)
dvice
03:07:33 08/14/13
I was considering running a leak down test...
-Grimm-
12:27:00 08/14/13
Re: Damn...
rhombicblue
13:48:25 08/14/13
