TwinTurbo.NET: Nissan 300ZX forum - pinched o-ring shouldn't fill a cylinder with fuel
Subject pinched o-ring shouldn't fill a cylinder with fuel
Posted by jkperformance on August 07, 2013 at 11:00 PM
  This message has been viewed 147 times.
In Reply To Deatsch Werks Injectors good or bad posted by GCamp on August 07, 2013 at 10:24 PM
Message The only way for that to happen is an injector stuck open, or completely mis-drilled for flow.
Are you still running the old style injectors, or have you swapped up to the newer style injectors that're less susceptible to ethanol and failure?
