| Subject |
Basically open the hood, disconnect the battery, and |
| Posted by |
300ZMang on August 06, 2013 at 7:16 AM |
This message has been viewed 194 times. |
| In Reply To |
Re: take all injector connectors off, ohm test injectors, clean posted by Auggie on August 05, 2013 at 03:53 PM |
| Message |
start cleaning all electrical harnesses you see... CAS, PTU, MAS, Injectors, TPS, Engine Temp, etc etc. Corrision - green crap. Scrape it off, carefully but meaningful and expose the metal on each end of the connectors. A lil dielectric grease will be good too. While injector connectors are off, ohm test your injectors, all should be 10-14 ohms, anything else they're toast.
| Follow Ups |
Post a Followup |
