TwinTurbo.NET: Nissan 300ZX forum - Yes, they cannot be repaired and must be replaced.
Subject Yes, they cannot be repaired and must be replaced.
Posted by Evan_Wright (Ca) on August 05, 2013 at 6:09 PM
  This message has been viewed 207 times.
In Reply To Re: A multi-meter would be a good start. posted by Auggie on August 05, 2013 at 03:55 PM
Message It is extremely common to see the old style injectors fail. It's so common that I would suggest only replacing them with the new style injectors that require different pigtails and fuel rail adapters. The old style injectors are prone to failure due to the ethanol added to fuels these days. You may want to research the "switched 12volt mod" while you're at it. Best way to search this site is to use google and add "site:twinturbo.net" without the quotation marks to your search terms.
