TwinTurbo.NET: Nissan 300ZX forum - A multi-meter would be a good start.
Evan_Wright (Ca)
on August 05, 2013 at 3:39 PM
Identifying Bad Injectors in 1991 TT
posted by Auggie
on August 05, 2013 at 02:51 PM
You can measure the resistance of each injector coil. They should all be 11-14 ohms. Most likely one or more is out of spec.
Auggie
14:51:53 08/05/13
A multi-meter would be a good start. -
Evan_Wright (Ca)
15:39:00 08/05/13
Re: A multi-meter would be a good start.
Auggie
15:55:35 08/05/13
Yes, they cannot be repaired and must be replaced.
Evan_Wright (Ca)
18:09:52 08/05/13
Never knew about the Google tip, thanks! (n/m)
Auggie
09:50:28 08/06/13
take all injector connectors off, ohm test injectors, clean
300ZMang
15:39:49 08/05/13
Re: take all injector connectors off, ohm test injectors, clean
Auggie
15:53:41 08/05/13
Basically open the hood, disconnect the battery, and
300ZMang
07:16:55 08/06/13
