TwinTurbo.NET: Nissan 300ZX forum - Loose the belt will wander
Subject Loose the belt will wander
Posted by Cjw3 on August 05, 2013 at 10:31 AM
  This message has been viewed 185 times.
In Reply To Re: Something is bent posted by tomas1329 on August 05, 2013 at 07:54 AM
Message You have something Driving the belt to the back. that will happen of an Idler pulley is sitting on a bent stud, or the Adjuster has Krap behind it ( a Washer ? ) and is not sitting square with the block. these things will drive the belt to a direction and it will wear.
If the Lower Washer on the Crank Pulley is installed backwards, it will shread the belt, but not force it to the back or front.
Cj
