TwinTurbo.NET: Nissan 300ZX forum - Re: Timing Belt Tensioner
Subject Re: Timing Belt Tensioner
Posted by brian913 on August 03, 2013 at 6:53 AM
  This message has been viewed 159 times.
In Reply To Timing Belt Tensioner posted by fastrnu90 on August 03, 2013 at 01:29 AM
Message The recommended way is to take the tensioner off, put it in a vice to squeeze the arm down and put the bolt back in. I have put the bold back in with it in the car but it is risky. If you do that you must tighten in down VERY slowly against the tension. Good luck!
