TwinTurbo.NET: Nissan 300ZX forum - Kiss it. Keep It Super Simple
Subject Kiss it. Keep It Super Simple
Posted by TTZ2NV(EPTmotorsports) on August 03, 2013 at 3:12 AM
  This message has been viewed 200 times.
In Reply To overheating posted by 300zx35 on August 02, 2013 at 05:49 PM
Message Here you go. check your clutch fan, if you sping the fan freely with no resistance its your clutch fan, if theres tension and you can not free spin it than its good. Your next then is to buy or rent a cooling system pressure tester to make sure your system holds pressure. If it holds pressure and your fan is good than there's a chance that you won't overheat if your idling but do when your driving it might be your head gasket. If your losin fluid with no leaks it's your radiator cap.
