TwinTurbo.NET: Nissan 300ZX forum - Re: That sounds a little sketchy.
Subject Re: That sounds a little sketchy.
Posted by -Grimm- on July 31, 2013 at 11:02 AM
  This message has been viewed 215 times.
In Reply To That sounds a little sketchy. posted by Krazyd27(Houston) on July 30, 2013 at 05:22 PM
Message I guess theoretically the cylinder could be at TDC on the compression stroke and force the head off when unbolted. I would imagine it to be more gradual than a forceful jump from the block though!
I think I will leave them off. Considering all the other corners I cut (only need ~10k out of this engine while I build the next one).
The head is a little thinner on that area there, but I have a feeling 6 ft-lbs isn't going to assist much considering the rest of the 90 ft-lb bolts. That and the fact it is an oil return (minimal pressure)
I will report back in a few thousand miles to let you know what happens.
Thanks
